BINARY OUTPUT FILES
  • August 9, 2017
  • 6894 views
I was wondering if anyone has written code to read in/write out the binary s01 (and other) files?
(I understand the structure of the file and yes I know I can output as ascii, I can do it with ascii but it is inefficient and my code writing skills are woeful)
Reason for request : I will retire before PTC to sort out node numbering and lack of signed vm stress.
skunks
Hello Roland,
1. vibration analysis => analytical (example attached)
2. static analysis => fatigue advisor
regards
paul
rrakos1-VisitorAuthor
Hello Paul,
1. In case of a simple modal simulation, I have for the first mode 100 Hz for example. For this mode, I have a stress distribution - for undamped case, as far as I know. But what does this stress distribution mean exactly? How can I it reproduce? If I complate a vibration analyisis with 100 Hz - for undamped case - then I dont get same stress distribution. What is the reason? How can I reproduce the stress distribution same to the first mode of modal analysis?
2. OK so I have a modal analysis; 100 Hz at the first mode. It is evident for me that this structure can not be used on this frequency. But if the frequency is 30 Hz for exmaple, how can I calculate the limit cycle number (until breakage)? The max stress on 30 Hz is 50 MPa (for example). Now have I to use the pdf (sent by you) and see the cycle number on 50 MPa?
Please help me.
Thanks a lot
Roland
skunks
Hello Roland,
i think: unfortunately, no.
regards
paul
