7-Bedrock
May 7, 2021
Creo Ansys Simulations fails to complete an analysis
I am using Creo Parametric 8.0 8.0.0.0
Analysis fails after mesh is created and 99% of the FEA is completed of a fairly complex assembly. The same assembly has been successfully analysed in Creo Simulate.
    NiloyGuhaAnswer
    7-Bedrock
    December 20, 2022
    Hi Dave,
    The issue got resolved in Creo 9.0.1.0. There was a problem in the previous versions of Creo Ansys Simulation.
    Niloy
    NiloyGuha7-BedrockAuthor
    7-Bedrock
    May 7, 2021
    The error message is attached.
    Opened C15883128
    For solution refer to article: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS344735
    I got it also in Creo 9.0.4.0
    7-Bedrock
    April 24, 2023
    That could be some other problem as the specific problem that I had faced in Creo 8 was finally resolved in Creo 9.0.1.0.
    Niloy
