Creo Simulate - contact Interfaces Being Ignored
- 2 replies
- 3032 views
- Translate All
Hello- I'm looking for some guidance on an analysis that I setting up inside Creo Simulate. I'm using some contact interfaces to allow rotation about a set of pins and it seems that Creo is ignoring these interfaces without warning, but it is evident in the results. I've added a screen shot of the problem (see below).
Rotation is permissible between the red pins and the light blue parts (hence the use of contact interfaces). With a load applied in the vertical direction (down) on the brown component, the gray actuator reacts this load and keeps it in position. This has a similar setup using contact interfaces but Creo seems to calculate this properly in the results.
Can anyone offer any insight on why Creo would be ignoring these interfaces? Any solutions that would correct this?
