Nov 20, 2014 1:57 PM UTC
How to convert large number of MS Word docs to XML
Is there perhaps a way to convert a couple of hundred MS Word documents to Arbortext XML. I know that you can develop a map template using import/export, but that isn't a viable option since there is a time constraint on the project and the documents are not necessarily similar in terms of formatting/styling. I'm hoping there is some sort of script that can be run to convert the documents. The ideal situation would be to convert to (specifically) DITA, but if I could just get the content into non-DTD specific XML (without having to copy and paste) that would still be great.
So, ideally a mass-conversion to DITA, but even just automatically getting it into XML for future manipulation would be a good result. Any ideas would be much appreciated!
    Nov 20, 2014 7:47 PM UTC
    I'm not really sure of the volumes you are talking about (200 x 10pp? 200 x 1000pp?) but for large volumes of documents, with mismatched styling, it is often easier (and cheaper) to send these offshore for processing. I can recommend a partner company we use if you're interested.
    I should note that if you want to do this by hand, Arbortext 6.0 and above let you copy+paste MS Word content directly in and it will be converted to XML on the fly. Not necessarily "perfect" XML but it gives you a starting place.
    rgrobler1-VisitorAuthor
    Nov 21, 2014 6:08 AM UTC
    Also, what is the process one should follow when doing the copy and paste? I invariably get an "invalid paste structure" response when attempting this. What am I missing?
    Nov 21, 2014 5:54 PM UTC
    Try searching the support Knowledge Base first. It might be that you are trying to paste into a custom DTD structure which is not configured for use with the "Smart Paste" feature.
