Jan 12, 2015 7:31 AM UTC
The problem about paste table in office word for the customized DTD.
Dear all,
I meet a confusing problem.
When I using the Arbortext default DTD, such as topic, concept, we can paste table in office word to the xml, and it can generate the <table>
automatically.
But I customized some DTD, and create the topic, when I paste table in office word, not only table, also text, the Arbortext Editor will promet "agettext: Msgid not found in message file: CopyPaste failed to convert clipboard". Every time paste...
After I changed the pastesource preference to mif;rtf;txt (delete the htm), it didn't promet "agettext: Msgid not found in message file: CopyPaste failed to convert clipboard" again, but still I can't paste table in office word to xml. it will generate the <p>.
Did I lost some setting, or steps, or some check for the DTD? Could you give me any tips please?
Thanks!
Jan 13, 2015 12:05 AM UTC
Sorry I'm not overly familiar with how to get this working but I do know that the "smart" copy/paste from MS Word uses the Arbortext Import/Export technology to do the MS Word to XML conversion. It sounds like you need to customise the Import/Export MapTemplate that is used for smart copy/paste to support your custom DTD.
lxie11-VisitorAuthor
Jan 13, 2015 1:47 AM UTC
Thank you Gareth, I will try to config and use the Arbortext Import/Export!
