May 21, 2012 6:46 AM UTC
How to create a new hatching template in Arbortext IsoDraw 7.1?
Hello!
I created two types of hatching in the file "Hatching_new.iso". One of them is "Type 1" - copied from the template file "DefaultHatchings.iso" in Arbortext IsoDraw 7.1 M070 (located on the path: C: \ Program Files \ PTC \ Arbortext IsoDraw 7.1 \ Program \ Patterns), a second type of "Type 2" - created new and, thus, does not work. Why is hatching "Type 2" does not work properly when hatching a closed object?
May 22, 2012 7:43 AM UTC
Type 2 is no perfect tesselation. You can see this easily if you manually copy the hatched square and align it to the first. Each lineend on one edge should match one on the aligned square.In your case, the diagonal lines have the same distance from each other, but a different distance from the corner of the square!
If you need a hatching with a defined distance of the diagonal lines you might need to adjust the size of the square.
VladimirN24-Ruby IVAuthor
May 24, 2012 3:38 PM UTC
Thank you for the answer. Yes, I need a hatching with a defined distance of the diagonal lines. This size of the frame for the sample hatching (square 50x50 mm) - is a prerequisite for a hatch pattern, or I can use another size (template file "DefaultHatchings.iso" use a square [50x50 mm])?
May 24, 2012 5:04 AM UTC
I am not that much good in english to explain,
So See the image and iso file.
You can understand why the problem occured.
May 24, 2012 3:39 PM UTC
Hello Vaduga,
Thank you.
May 31, 2012 11:10 AM UTC
Does anyone know where is the pattern "CGM_Hatching" placed (in which the program directory of Arbortext IsoDraw, because the file "Cgmhatchings.cgm" (placed in directory "C:\Program Files\PTC\Arbortext IsoDraw 7.1\Program\Patterns") is empty)?
Jun 1, 2012 4:11 AM UTC
Jun 1, 2012 7:18 AM UTC
Thanks!
