REQUIRE HELP ....
  • January 5, 2018
  • 1968 views
Dir Sir/Madam,
 I am Nilesh, using  creo 2.0. I am trying to determine maximum no. of given objects and its alignment  that can be added in given volume. is there any method to do same. please help me out. Thank you
Are you referring to https://en.wikipedia.org/wiki/Knapsack_problem ?
If so, then Creo has no such method.
