3.0 to 2.0
  • December 17, 2014
  • 2 replies
  • 4166 views
How can I open a file created in Creo 3.0 on a machine with Creo 2.0?
Best answer by MartinHanak
Matt,
use GRANITE®-Based Cross-Release Interoperability (GCRI) Functionality Implemented Starting in Pro/ENGINEER Wildfire 3.0. (see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34964).
Follow the 2 steps below:
  • Copy the readnewermodels.dll file from the upper version folder
    • For Creo Parametric 3.0
      • Copy readnewermodels.dll from <Creo load point>\<datecode>\Common Files\<machine_type>\gcri
  • Paste the readnewermodels.dll file to the lower version in the following folder
    • For Creo Parametric 2.0
      • Put the readnewermodels.dll into <Creo load point>\common files\<datecodes>\<machine_type>\obj\
Now you can start CR2 and open CR3 file.
LIMITATION: You will not see feature history !!!
Good luck
Martin Hanak
Welcome to the forum, Matt.
Technically, you cannot. You can export the file as STEP and open it in Creo 2.0 but I know that is not what you are after. There is a utility called Granite that can do this but the file will be compromised from the original parametric point of view.
If there is a critical need, you might ask customer support to give you a hand on this. But in general, you cannot do this if you want all your features transferred intact.
Matt,
Good luck
Martin Hanak
