Sep 14, 2015 10:55 AM UTC
Create DXF
Is there a way to create a 2D DXF of a part automatically?
We have a template with only 1 view with an orientation DXF. Now I would like to make a mapkey so automatically the drawing is created out of the part and also the drawing then is saved as DXF
Sep 15, 2015 6:05 AM UTC
Danny,
I created an example for you, see x1.zip file.
  • x1.prt ... testing prt located in working directory
  • x1_template.drw ... testing template located in working directory
  • x1_mapkey.pro ... mapkey dxf
My testing procedure:
  • add the contents of x1_mapkey.pro into config.pro located in working directory
  • start Creo Parametric 2.0 M070
  • open x1.prt
  • run dxf mapkey
  • enter x1 when asked to Enter drawing name
If you want to automate entering of drawing name, then you have to use combination of AutoIt(AutoHotkey)+trail file+mapkey.
Martin Hanak
2-Explorer
Sep 15, 2015 5:10 AM UTC
Try this:
mapkey $F2 ~ Command `ProCmdModelNew` ;~ Select `new` `Type` 1 `Drawing`;\
mapkey(continued) ~ Activate `new` `OK`;~ Activate `dwg_create` `psh_ok`;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdExportPreview`
mapkey(continued) ~ Command `ProCmdDwgPubSetDeliverable`  `DXF`;\
mapkey(continued) ~ Command `ProCmdDwgPubExport` ;~ Activate `file_saveas` `OK`;
Danny,
  • open x1.prt
  • run dxf mapkey
Martin Hanak
Sep 15, 2015 4:38 PM UTC
Hi, it does not work 100% automaticly, becouse you have to set DXF view in model before.
I mostly need to create DXF of sheetmetal parts. 'I have to set up dxf view before. It is nice there is "Flat Pattern Preview" but I can't save that view.
Does somebody know how to create DXF of sheetmetal part 100% automaticly by mapkey in creo2?
Sep 16, 2015 11:05 PM UTC
Can you share a sample part and the template you pretend to use to give it a try?
Jose
