PhotoLux Render Issues
  • December 20, 2011
  • 16 replies
  • 11608 views
Windows 7 Ultimate 64-Bit
8GB RAM
NVIDIA GT 550M
Creo Elements Pro 5.0
Every time I try to render using PhotoLUX, the result is a solid black screen. I can render using PhotoRender but the quality isn't that great.
I have tried every scene, moving floors/walls/etc, adjusting lights, adjusting effects...all with the same result.
I have tried Draft to Maximum quality. Output Full Window to JPEG to TIF...all the rendered files are solid black. It's driving me insane! I've followed as many tutorials as I can...step by step, but my result is solid black as opposed to the tutorials results of a completely rendered model.
Has anyone experienced anything like this? Have any Ideas?
Any help will be greatly appreciated!!!
Best answer by BulldogFan7
Ok everyone...I finally figured it out. It was McAfee Internet Security. Not sure how it blocked it but as soon as I uninstalled McAfee, the rendering works perfectly.
Wish I knew this from the get go.
That´s weird you should check maybe your materials, i recomend to use only PhotoLUX scenes and materials (the last ones), your computer is perfect.
I went back to check all my materials...and I am using PhotoLUX visual styles and am using a PhotoLUX scene.
It's frustrating because I'm following all the instructions i can find online and it still is not working. I'll post a picture of what it looks like when I render a small section.
Floor nor walls are causing the issue...they are not in front of the model.
Also...I'm looking in Floating Modules and I don't see where there is an Advanced Render option. Should that be there?
Did some advice appear when you select PhotoLUX?
No, there was not advice. Other than it being black, PhotoLUX works fine.
BulldogFan71-VisitorAuthorAnswer
Cool man finally hehe.
