2-Explorer
September 29, 2016
Pro programming user guide
  • September 29, 2016
  • 35 replies
  • 37032 views
Has anyone come across user manual or any help file of pro program?
Ketan
    2-Explorer
    September 30, 2016
    This may help https://www.youtube.com/watch?v=930o_03tlGo
    Personal notes:
    When a Pro Program is edited the information will come from the file the first time. The editor will create a copy of the file program as-is for backup purposes. After that it will ask "From Model' or From File." If the last time turned out poorly, then 'From File' is your best choice.
    When a program is run:
    • Current Vals will run unaided;
    • Enter will show the choices to change and then prompt you to change the selected ones;
    • Read File will get the values from a file you select.
      Any values in the program and not in the file are unchanged, any values in the file and not in the program are ignored.
    Example file entries - one per line; case-sensitive
    THICKNESS = 2.5
    INCLUDE_VALVE = YES
    MATERIAL = "STEEL"
    Comments
    /* < your comment
    Place the comment immediately after an ADD to keep its place with the feature.
    Input
    Types:
    • Number (default)
    • String
    • Yes_No.
    Must exist between INPUT and END INPUT.
    Can use IF-ELSE-ENDIF
    IF-ELSE-ENDIF
    logical operations are >,<, ==; string literals are in quotes.
    Component Replacement
    Get the name of the replacement from INPUT or via RELATIONS
    Change the ADD PART to ADD PART (replacement) for part to part exchange
    or
    Change the ADD COMPONENT(replacement) for part to subassy exchange.
    "COMPONENT" requires file extension, PART does not.
    Relations
    Must be between RELATIONS and END RELATIONS
    XYZ = <parameter_name>:fid_<feature_name>:<comp_id>
    or
    XYZ = <parameter_name>:fid_<N>:<comp_id>
    Family table based replacement
    The format for lookup_inst is:
    lookup_inst ("generic_name", match_mode, param_name_1, match_value_1, param_name_2, match_value_2,...)
    where:
    generic name—Name of the generic model with a .prt or .asm extension
    match_mode—One of the following values:
    –1 (find closest instance with param values less than or equal to supplied values)
    0 (find instance with param values that match supplied values exactly)
    1 (find closest instance with param values greater than or equal to supplied values)
    param_name_1—Family table parameter name
    match_value_1—Value to match against
    User-Defined Features
    CHOOSE (<ID>)
    All the available IDs can be found in the ADD statement of the leader of the currently active group in the Program listing
    To use a CHOOSE statement, you must first manually replace a family table instance of the group or replace the group with another group.
    CHOOSE statements cannot be included in conditional statements.
    EXECUTE
    Replaces the ADD end END ADD
    This is for assemblies to link assy input variables to program variables in assembly components.
    EXECUTE {PART}/{ASSY } name or variable
    input variable of design at next lower level = expression
    input variable.....
    END EXECUTE
    Only reaches one level, but that level can domino to the next.
    Can be used with IF-ELSE-ENDIF
    MASSPROP
    MASSPROP
    IF THICKNESS > 1
    PART PLATE
    ELSE
    ASSEMBLY BLOCK
    ENDIF
    END MASSPROP
    INTERACT
    Can be inserted anywhere within the FEATURE ADD - END ADD or PART ADD - END ADD statement
    Stops program execution and uses FEAT CLASS menu to allow additional work to be done on the model.
    ADD, ADD SUPPRESSED
    MODIFY - changes dimensions
    MODIFY d# = value
    Hi, D,
    1. It is not possible to add comments in the INPUT block? I get an error every time I add "/*":
    /* A STRING
    !*** ERR: not a valid line for the INPUT statement
    2. There is not possible to define an INTEGER parameter in the INPUT block? Only "NUMBER" (real)?
    B INTEGER
    !*** ERR: line contains a bad symbol or is otherwise invalid
    Nic.
    2-Explorer
    April 10, 2017
    If you read the document that DCG supplied you can see that comments don't apply to the INPUT section.
    It is not possible to use INTEGER to define an input type.
    Here is the guide from Widlfire 2.0.  http://www.datajett.com/Cadd/ProE/Wildfire_Help/program.pdf
    There was a guide from Wildefire 4.0 but can't find that one.  However, they are basically the same.
