3-Newcomer
Rigid link versus weighted link
hello Everybody
I have a model where I want to assign a mass , but this mass is outside the model.
First I have created a point where my mass will be located but I don't know what is the best solution to link the point and the model
Use a rigid link or use a weighted link ????
Many thank for your help
Olivier
    Weighted link allows the reference geometry to deform, the rigid link does not. I'd use weighted link if I can (it's ony available in the advanced version of simulate).
    A limitation of the weighted link, is that you can't apply a constraint to the dependent point, but there's a workaround for that. This shouldn't be a problem in your case since you want to apply a mass.
    /Mats L/Product specialist, simulation tools/Econocap Sweden/
    opavot3-NewcomerAuthor
    3-Newcomer
    Dear Mats
    Many thanks for the explanation
    OP
    Ici j'ai fait un petit presentation de ce sujet:
    http://www.youtube.com/watch?v=keMLlyec4B8
    En suedois, mais je crois tu comprends...
    /Mats L
    3-Newcomer
    Dear Mats
    not easy to understand beacuse I don't speak the language
    OP
    It describes three different methods to constrain a shaft subject to bending and torsion, using three different methods. I use regular constraints (erroneous), rigid links (correct, but yields unnatural stress distribution around constraints), and weighted links (correct, no unnatural stress distribution, but more complicated to create).
    Video Link : 3069
    can someone share the original proe file to see the 3 methods.
    Hello, NAPOLEON,
    The topic has been reactivated, it would be interesting if your application file sharing could be heard.
    This is a very interesting example, as we do not often see.
    Cordially.
    Denis.
