Which JAVA version do I need with CREO 3.0 J/LINK
Is it the same as the first CREO or did they update j/link?
    Hi
    Hi Jens-Uwe Nixdorf‌,
    Thanks for catching this.  I've moved this thread to the Creo Community.
    Kael
    18-Opal
    September 19, 2016
    Hi Bill,
    I found some information, that may be helpful in article CS111722.
    • The J-Link application should not be compiled with a newer JDK than the Java Run-time version used on the clients
    Amit
    in http://support.ptc.com/WCMS/files/160242/en/PTC_Creo_Future_Platform_Support_Summary.pdf you can find ...
                                                         Creo 2.0                     Creo 3.0                      Creo 4.0
    MH
