Creo Additive MFG Tips & Techniques Session Recording (West Coast)
  • April 15, 2026 at 3:21 PM
  • 12708 views
  • Translate All
Check out this video on Creo Additive MFG from PTC Application Engineers
Presenters: Lino Tozzi (Solution Consultant, Fellow) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: November 14, 2023
To dive deeper into the subject, check out Creo Additive MFG.
WEBCAST Q&A
Question from Kevin:  Is "Part from body" associative?  Will updates in the first model be passed to the second model?
Answer:  It is automatically associative.  If you want to turn it off you can select "edit definition" on the External Copy Geometry feature in the part created from the body, and under the options tab, select "Automatic Update". "Manual Update" or "No Dependency".
