Creo Ansys Advanced Tips &. Techniques
Check out this video on Creo Ansys Advanced from PTC Application Engineers. Presenters: Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
WEBCAST Q&A
Question from Anonymous:  Do we have the possibility to create partitions to define more precise the elements for mesh?
Answer:  Yes, each surface can have it's own mesh density,  Multi-Body can be used to create a volume mesh density.  In Creo 9.0, individual surfaces can be divided / broken up to apply more localized mesh densities and/or loads.
Question from Anonymous:  Are there benefits to using joints over contacts if contacts give better results?
Answer:  If the area of concern is away from the joint, then joints are easier.  Otherwise, the contacts will show stresses at the contact regions.
