Dec 6, 2022 9:10 PM UTC
WEBCAST Q&A
Question from Daniel:  Can autoscaling be turned off?
Answer:  Yes, the option is - sketcher_auto_scale_dimensions "yes/no".
Dec 6, 2022 9:12 PM UTC
WEBCAST Q&A
Question from Dominick:  Can you remove just the pattern without removing the "base" feature in Creo 9?
Answer:  Use "Delete Pattern" and it does just that.
Dec 6, 2022 9:13 PM UTC
WEBCAST Q&A
Question from Trevor:  Can you split a surface using only a line, or does it need to be an enclosed shape?
Answer:  Just a line will work as long as it reaches the current surface boundary.
Dec 6, 2022 9:15 PM UTC
WEBCAST Q&A
Question from Zachary:  If you split the surface, can you apply different properties?
Answer:  Yes.  Try various properties that you might need.
