Apr 26, 2022 1:24 PM UTC
Creo Parametric Automation
  • Apr 9, 2026 5:47 PM UTC
  • 2 replies
  • 1681 views
  • Translate All
Check out this video on Automating Creo Parametric from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia  (Creo Segment Sales).
May 23, 2022 4:05 PM UTC
Webcast Q&A
Question from Calvin:  Option Modeler - is this available in Creo 8?
Answer:  Yes, it is available for Creo 8.
May 23, 2022 4:08 PM UTC
Webcast Q&A
Question from Charles:  What happens with these "partners" go out of business or decide not to support Creo or even decide not to continue to update to the latest Creo version?
Answer:  The end result of the work here is just a Creo assembly as if you built it manually.  Smart Assembly only works with Creo.  It should work with your current release of Creo indefinitely.
