Creo Parametric Progressive Die Tips and Techniques
Check out this video on Creo Parametric Progressive Die Tips and Techniques session  from PTC Application Engineers.
Presenters: Lee Goodwin (Solution Consulting, Principle) and Ryan Butcher (Solution Consulting, Fellow).
Creo Progressive Die Learning
WEBCAST Q&A
Question from Mark:  In terms of designing a part, how is PDX different from Creo Sheetmetal?  I've used Sheetmetal but when would i need to use PDX?
Answer:  Sheetmetal is the design phase in the process.  PDX is for developing/designing the tooling for the manufacturing process.
Question from Mark:  Thank you for the last question.  Similar to PDX, is there a tool for injection molding die design?
Answer:  Yes, Expert Moldbase (EMX).
WEBCAST Q&A
Question from Sandeep:  Does one need a separate license for adding the PDX plug-in, inside the already existing Creo toolbar?
Answer:  Yes, it is an add-on extension.
