Creo: "Things You Might Know, but Probably Don't" Tips & Techniques Session Recording (West Coast)
Check out this video on Creo: "Things You Might Know, but Probably Don't from PTC Application Engineers. Presenters:  Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: September 19,, 2023
To dive deeper into the subject, check out Creo UI Tips.
WEBCAST Q&A
Question from Abby:  We'd like to be able to organize the sketches we add to the sketch palette but looks like you can only add one tab.  Is that correct?
Answer:  If you go to your install of Creo, you can add your own folders to the sketcher palette folder.  Here is my location: C:\PTC\Creo 10\Creo 10.0.0.0\Common Files\text\sketcher_palette.  Then you can add sketches to as many folders as you like.
WEBCAST Q&A
Question from Joanne:  Can you still drag  if the sketch dimensions are locked?
Answer:  The sketch will not move in the directions that dimensions are locked.  You would just RMB and unlock the dimensions.  Then you can move freely.
