Oct 18, 2023 4:59 PM UTC
Creo: "Things You Might Know, but Probably Don't" Tips & Techniques Session Recording (East Coast)
  • Apr 7, 2026 8:42 PM UTC
  • 6 replies
  • 64533 views
  • Translate All
Check out this video on Creo: "Things You Might Know, but Probably Don't from PTC Application Engineers. Presenters:  Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: September 21,,2023.
Oct 20, 2023 1:48 PM UTC
Webcast Q&A
Question from Anonymous:  Can you explain/show  how to use the "seed and boundary surfaces" selection tool well?
Answer:  Pick any surface included in the selection / shift /boundary surface and let go.
Question from Anonymous:  Can you pick more than 1 boundary surface?
Answer:  Yes
Question from Anonymous:  I apologize for this question not being related to what is being demo'd, but is there a way to select multiple entities without having to hold Control?  For example, when picking surfaces for a Copy feature or for a Shrinkwrap, if you have multiple selected, and accidentally select another without holding Control again, you lose everything you've picked up to that point.  Is there a collector mode or something?
Answer:  This would be combination of seed/bounds and CNTRL for additional selections.
Oct 20, 2023 1:50 PM UTC
WEBCAST Q&A
Question from Gabriele:  Can you explain again how you get to the Edit definition mini menu?
Answer:  Once picking a feature, Right Mouse Button, and pick the ball with the pencil.  You can also pick the feature in the model tree and RMB.
Oct 20, 2023 1:53 PM UTC
WEBCAST Q&A
Question from Keith: Once you center button click to place a palette sketch can you ever get back to the interface that shows the rotation and size of that palette sketch?
Answer:  Yes
Oct 20, 2023 1:56 PM UTC
WEBCAST Q&A
Question from Kevin:  Isn't one of the Intent References all edges of the feature?
Answer:  Not really.  In the case of extrude, it would be all of the edges in the direction of the extrude.  There are other ways to select all edges in a feature (pick box, etc.).
Oct 20, 2023 1:59 PM UTC
WEBCAST Q&A
Question from Marty:  How do you rotate the view while selecting multiple boundaries?
Answer:  You can spin / shift / boundary, Toggle with shift key.
Oct 20, 2023 2:01 PM UTC
WEBCAST Q&A
Question from Tom:  Can you selectively remove an edge from intent selection?
Answer:  No, as the "intent" is to select all of the edges as a feature.
