What's New in Creo 9.0 Tips n' Techniques
Check out this video on Creo 9.0 from PTC Application Engineers
Presenters: Jason Petersen (Technical Specialist, Principal) Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
Hello Lino
Can we make mill surface with the split method in manufacturing?
Regards
Pushkar Khanna
WEBCAST Q&A
Question from Artug:  Is Keyshot 11 not supported by Creo 9?
Answer:  Keyshot 11 will be added in future versions of Creo.
WEBCAST Q&A
Question from Brian:  What type of curves, not just rectangles or circles?
Answer:  You can use curves to project, curves, lines, splines, etc.
WEBCAST Q&A
Question from Dietmar:  In assembly view, can I set parts to semi transparent?
Answer:  Starting in Creo 8.0, you can pick any body or component and "make transparent".
WEBCAST Q&A
Question from Joe:  Any new tips to create a product label without using images?
Answer:  You would need to pre-build your sketch and use it as opposed to use a label.
WEBCAST Q&A
Question from Joel:  Does the "make inseparable" command preserve the parametric flexibility (created through Pro/Program) of subcomponents?
Answer:  This creates a new file with many caveats.  A large window pops up with many of those caveats.  Pro/Program commands may be lost.
WEBCAST Q&A
Question from Jon:  With split surfaces, can you apply hatching for Datum Target area within MBD?
Answer:  Yes.
WEBCAST Q&A
Question from Sergio:  Are welding symbols improved?
Answer:  Yes, there were some improvement.
