Dec 18, 2018 5:18 PM UTC
Mass attribute relations
I am investigating using Mass properties from Creo in Windchill, at the start of a project we want to use the calculated mass, then as we get real parts and weigh them, we want to enter this into the Alternate Mass PRO_MP_ALT_MASS and use that in Windchill, but we don't want to have 2 different mass attributes on each CAD document as we want to compare CAD mass (calculated or alternate) to an target mass attribute in the WT part.
So I have created a new parameter called "MASS" and I want this parameter to equal the value of PRO_MP_MASS or the value of PRO_MP_ALT_MASS but only if it does not equal zero.
I struggling to write this and get it to work in Relations, can anyone help?
BenLoosliAnswer
Dec 19, 2018 3:07 PM UTC
This worked for me:
if pro_mp_alt_mass <> 0
weight = pro_mp_alt_mass
else
weight=pro_mp_mass
endif
The key is to have the pro_mp_alt_mass value entered for your part. If it is blank, then the relations fail.
Add pro_mp_alt_mass to your model tree and then enter the value. I tested it with both a 0.0 and a positive value, 7.25, for my test part.
KenFarley
Dec 18, 2018 5:57 PM UTC
I don't know if you're having difficulties because you're trying to use built-in things like PRO_MP_MASS, but the relations code should be relatively simple, something like:
MASS = PRO_MP_MASS
IF PRO_MP_ALT_MASS > 0.0
 MASS = PRO_MP_ALT_MASS
ENDIF
Dec 19, 2018 10:05 AM UTC
If I try to verify with neither parameters having a value I get the following errors:
MASS = PRO_MP_MASS
errorInvalid data type combination at right side of expression
errorLeft and right sides are incompatible
ENDIF
Does it need to check the parameters are not null before the If statement?
TomU
Dec 19, 2018 1:31 PM UTC
