11-Garnet
Feb 18, 2020 5:57 PM UTC
Exclude entire parts from export
Hi all,
Can I exclude specific parts / sub-components from a step export?
I've got assemblies imported from a supplier which are purchased in already assembled, so I'd like to exclude the sub-components from my step file export (which, in turn, will exclude them from my BOM).
In the past I have used a parameter added to parts/assemblies to exclude those parts from a Windchill wtp BOM, but I'm using step files and a third party software to create the BOM now so I'm wondering can I do something similar to control the structure of a step file?
Thanks in advance 🙂
StephenW
StephenWAnswer
Feb 18, 2020 6:48 PM UTC
I use simplified reps to exclude items from export. Not sure this really applies to your situation.
StephenW
StephenW23-Emerald IIIAnswer
Fianna11-GarnetAuthor
11-Garnet
Feb 25, 2020 11:58 AM UTC
Thank you both 🙂
I use layers in parts but I'm not a big fan at assembly level so I think I'll just set up an export rep and keep it updated as I add new parts.
Cheers 🙂
TomU
Feb 18, 2020 6:55 PM UTC
Yes.  Set the config option intf_out_blanked_entities to no, then just hide anything you don't want in the export.  (Place on a layer, use a simplified rep., or just select the objects and choose 'Hide'.)  With this option set to 'no', only visible items will be included in the export data.
