Sep 24, 2013 10:27 AM UTC
Exploded States, can you use an existing exploded state of a sub-assembly in a top level model?
I am producing an exploded drawing of a top-level assembly which includes a number of sub-assemblies with existing exploded views. My question is can I use these existing exploded views of the sub-assemblies in the top level assembly. I want to turn the explode state on some of the sub-assemblies so I can use the selected Flat BOM in the top level to identify all the parts.
Any help would be appreciated.
Dec 18, 2013 3:16 PM UTC
This is possible when using the Default Explode. When activating the default explode of the top level assembly, also the default explode of the subassemblies are triggered.
Tip 1: Existing exploded views can be saved as Default Explode, no rework has to be done.
Tip 2: The default exploded state on the top level can be saved under a different name. This way in combination with Tip 1, multiple exploded states can be transferred to the top level (via the Default Explode)
