Export only visible parts from an assembly?
  • May 3, 2017
  • 11 replies
  • 25865 views
Is there an easy way of exporting only visible parts from an assembly? I received an assembly with a lot of subassemblies with a lot of subassemblies with some hidden parts. I will take me a lot of time to find every hidden part in every sub-sub-subassembly and exclude them individually in the STEP export dialog.
Best answer by TomU
Assuming you're using Creo Parametric, you can add the config option intf_out_blanked_entities no.  With this set to 'no' only the items that are visible on the screen will be exported.
TomU23-Emerald IVAnswer
I did not find this "intf_out_blanked_entities" in creo 4. Please help
