Jul 23, 2019 9:24 PM UTC
Repeat Region table fitting on the sheet
My repeat region (for BOM) is vertically extending for assembly and going outside of sheet. Is there a way to break or divide table so it does not keep growing vertically and could fit into sheet.
Thank you
Jul 25, 2019 4:46 AM UTC
@NP_01 wrote:
Yes it did help. Although, I wanted to show all the footer such as item no. material etc. and also show the rest of paginating rows in one shot than individually showing each item row and then aligning each them.
Thank you for your help.
unfortunatelly I do not understand your note. I hope you used Add Title command from TBL PAGIN menu to add header row to each table segment.
Jul 24, 2019 10:56 AM UTC
you can split large repeat region table to several drawing sheets using Paginate command.
See https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/index.html#page/detail/About_Paginating_Report_Tables.html
NP_011-VisitorAuthor
Jul 25, 2019 1:33 AM UTC
Jul 25, 2019 10:16 PM UTC
Yes it did work as you suggested.
Thank you
