individual dual dimension control
meng1
Have a situation where I would like to be able to control the use of dual dimensioning on selected drawing dimensions in CREO 4.0.  Is this possible and if so can you provide the step needed for a new CREO user?  THanks in advance!!
4 REPLIES 4
dschenken
(To:meng1)
Add it as a note.
Dimensioning standards, such as ASME Y14.5, specifically eliminated dual dimensioning because it is a poor practice.
TomU
(To:dschenken)
@dschenken, do you have a reference for this statement?  I don't disagree, and I'm aware the verbage was removed from the standard, but I've never seen anything that actually says why.  I've love to see the written justification (and pass it on) if it exists.  Thanks.
dschenken
(To:TomU)
It wouldn't be eliminated because it was a good practice.
The frustration of the Y14.5 committee is they don't publish reasons, for reasons they won't get into.
The general explanation on D&T forums is that, due to precision problems in conversion, dual dimensioning leads to two interpretations of the limits and this conflicts with the rule that there not be multiple interpretations of the drawing requirements.
KenFarley
(To:meng1)
I am using Creo 2, but as far as I know the dual dimensioning is either on or off. You can't set it for specific individual dimensions.
