How to pass the parameter in Walk Query Section?
  • March 17, 2016
  • 2 replies
  • 2656 views
I don't how to pass parameters in the walktestsession Query?
for(var i=0;i<testSessionsDetails.length;i++)
tempSessionID=testSessionsDetails[i].toString();
<%beginrelationshipsdetail Query[(walktestsession[tempSessionID])]%>
alert("<%Relationship Expected Results%>");
<%endrelationshipsdetail%>
If I pass the value directly then it is working fine, but if we try to assign either Integer or String value then it is not accepting.
<%beginrelationshipsdetail Query[(walktestsession[“3856”])]%>
Any help would be really appreciated.
Thanks in Advance,
Sithik
    Best answer by srahamedhulla
    Hi Michael,
    There is some limitation to this.We can't pass the variable in the tag.
    The below tags works for me
    <%RelationshipL2 Tests As Of Date%>
    <%beginrelationshipsdetailL3 Query[(walktestsession[<%RelationshipL2 ID%>])]%>
    Sithik
    Hello Sithik Rahamedhulla,
    When you dump the tempSessionID in the first example, is it the actual item ID or is it some other value?
    Kael
    Hi Kael,
    Sithik
    Sithik,
    Assuming like Kael mentioned, that your tempSessionID, is resolving to what you expect, does this format work for you?
    <%beginrelationshipsdetail Query[(walktestsession[<%<%tempSessionID%>%>])]%>
    srahamedhulla1-VisitorAuthorAnswer
    Hi Michael,
    Sithik
