Euromap 77 and OPC-UA client
Anyone has experiences in connecting with IMM through Euromap 77 by using OPC-UA client driver?
From what I know Euromap77 is OPC-UA based, so I suppose we can use OPC-UA client driver to collect data.
And if don't use OPC-UA client driver, is there anyway to connect through Euromap 77?
cmoreheadAnswer
@AT_10876945
Please take a look at the following article:
https://www.ptc.com/en/support/article/CS397586
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
For future reference, additional articles relating to Kepware/ThingWorx Industrial Connectivity can be found here:
https://support.ptc.com/search/Pages/results.aspx
Best regards,
*Chris
cmorehead13-AquamarineAnswer
@AT_10876945
Best regards,
*Chris
