Feb 6, 2020 11:41 AM UTC
Is there a PTC recommended or easy way to connect two instances of Kepware?
We have two instances of Kepware, one Kepware is connected to DST machines, the other one is more of a central server which gets machine data in OPC UA from third party apps and feeds data to Apps for analysis. both the Kepware instances can be connected via OPC UA connection. But is there any PTC recommended way to do this?
Feb 18, 2020 7:35 PM UTC
Using the OPC UA client driver, you can make an OPC UA connection from one KEPServer install to another. OPC UA is preferred over OPC DA as it is more secure.
Please see this support article for more assistance
https://www.ptc.com/en/support/article/CS298913
Kind Regards,
Andrew Black
Kind Regards,
Andrew Black
Support
Feb 26, 2020 3:42 PM UTC
Hi @Manav_Pampher.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
