Add Datum Axis for all the Holes in Parts built from Neutral Files
  • June 2, 2015
  • 3 replies
  • 3896 views
Hello all,
I'm looking for an application that will add datum axis for all the holes in a part generated via importing neutral files.
We use these parts for programming (Pro/NC) - mostly plates with lots of holes on all faces.
We have a large library of UDFS built for native Pro/E files and they ask for axis selection, therefore it would save a lot of time to prepare these parts and add all the axis before working on the manufacturing file.
Any suggestion is appreciated,
Thanks a lot,
Anca
Best answer by TomU
There is a free Toolkit application called "AutoAxis" that will do what you're looking for.  I haven't used it since back on Wildfire 2, but it looks like it's still available.  Take a look at these links:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS48511
AutoAxis Windows 7 64bit
TomU23-Emerald IVAnswer
Can someone of you, share this AutoAxis compiled application?
Thank you very much in advance.
My email thien94qn@gmail.com
can you share me. I need it very much. thank you, my gmail phucloi.2311@gmail.com
By the way, here is a nice guide on how to install it:
http://www.codexcreo.com/setup_use_of_autoaxis.pdf
abolovan1-VisitorAuthor
Brilliant!!! It’s exactly what I was looking for. Actually is even more because it's grouping the axis based on diameter
Thank you so much, Anca
