Cannot Install. Can't see selected application
I am still in the stage of installing mathCAD. When I am in the wizard, I am unable to see any applications to select in the 3rd stage. (Application Selection) I can only see where the default installation path is and I am also unable to see where I can browse another path if you have that setting. I hope you understand my problem and able to fix this or send another installation folder that doesn't have this problem. Thank you in advance,
Kind regards,
Billy
VipulTAnswer
Hi @WW_9806318,
Verify that you have complete admin privilege's over the system
Also, run pim_installmgr_mathcad_6V2.exe as administrator. https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download/install
Vipul
VipulT16-PearlAnswer
Hi @WW_9806318,
Vipul
