2d linear interpolation
  • March 5, 2018
  • 4325 views
Dear all,
I'm facing again a problem with linear 2D interpolation.
In this case I tried to see if the results of direct and inverse interpolation coincide.
z=f(x,y) and y=f(x,z).
Unfortunately, they don't.
Could you please help me in finding the solution of this problem?
Attached you see the mathcad file.
Thank-you very much for your support.
Enrico
Sorry, but I see no reason why the two diagrams in your sheet should coincide.
Your first table yields a value for cycles  of 35309 if force=16574 and ratio=0.2.
Your second table suggest a cycle value of just 100 for the same values. Obviously different functions.
ebelmonte1-VisitorAuthor
Dear Werner,
Thank-you very much for your reply.
You are right. I've sorted out the file. Now it should be clearer.
I still find some difficulties by interpolating the data.
I really appreciate your support!
Enrico
Dear Werner,
Why are there value which do not correspond?
Is that due to the fit function you use to provide the inverse function?
below you find the function.
In the direct function I calculate the "N" while in the inverse function I calculate sigma.
The tables from excel are correct. Why shouldn't not work with mathcad?
Thank-you very much for your support!
