Jun 19, 2020 2:11 PM UTC
Grid on a 2D Plot
Prime 6 does not appear to have a way to produce a grid on a 2D plot.  Without a grid, plot values are difficult to read.  Hopefully this glaring omission will be corrected in Prime 7.  It would be good to have major and minor grid lines, of different colors and weights, but as a minimum the plotting features of MathCAD15 should be included.  A related helpful feature would be to be able to control the orientation of polar plots.  A current need is for a polar plot with zero degrees pointing to the left rather than to the right, with positive angles opening counterclockwise.  One could imagine zero degrees straight up, with positive angles opening clockwise, or other orientations and directions.
I posted this before and got a response to the effect that showing a grid is possible in Prime6 by way of some kind of plot editor.  But I can't find any such thing anywhere in Prime6.  If some tool is to be used, it would be helpful to know where to find it.
terryhendicott
Jun 19, 2020 3:18 PM UTC
On the ribbon under Math | Regions | Chart Component is a drop down list, select Insert chart component.
Set the x and y values you get a plot.
Double click the plot opens up a whole plot editor where you can set X and Y gridlines.
Cheers
Terry
terryhendicott
Cheers
Terry
23-Emerald V
Jun 19, 2020 3:20 PM UTC
But... can you set a Polar plot?
terryhendicott
Jun 19, 2020 5:34 PM UTC
You can set a polar plots orientation see fie below.
Cheers
Terry
Jun 19, 2020 5:28 PM UTC
We need grid for papier plots, not for a live plots with markers. I think so!
23-Emerald V
Jun 20, 2020 11:05 AM UTC
a) Not just (physical) paper plots, but any non-live Mathcad plot, such as an image in an on-line article.
b) Adding markers is a mandraulic(*)/ трудоемкие(?) task.  IME, it's cognitively less challenging to glance across a grid.
I like Prime's extra horizontal and vertical markers, but I'm not at all sure that they are the better choice for skimming through an article and picking up information at a glance.
Stuart
(*) Please substitue suitably gender-neutral term of your choice.   'humandraulic', 'persondraulic', 'needlessly operose and mildly vexatious'
23-Emerald I
Jun 20, 2020 11:29 AM UTC
To show what could be done with a little ingenuity, attached is a file (courtesy of Luc and Werner, IIR) that draws grids and works in Express
