Mathcad Prime 5.0 automatically converts my defined units to base units
- 1 reply
- 1723 views
- Translate All
Hello PTC Community,
I am working on mathcad prime 5.0.0 and I have been facing an issue regarding the unit conversions.
As you can see from the screenshot attached ('scrn1'), I have explicitly defined a variable "MGR" to have ft.lbf unit but when I print / display it, the units are automatically converted to its base units.
A possible work around is to 'forcefully' change the units in the block where I have printed the result (refer to scrn2 and scrn3). However, I have not been able to find a permanent fix.
I would appreciate if anyone can help me out.
Thanks.
