Prime backwards compatibility - solved? Or at least hacked
  • November 21, 2019
  • 3710 views
Given how little versions changed, it has frustrated us all that we cannot save in older versions.  I suspect this is largely a marketing ploy to force upgrades and new purchases. And, probably controlled by a simple version check.  So after a little thinking, digging and experimenting, I have been able to open 5.0 files in 4.0.  I haven't played with it much and I'm sure it's limited - but it might help someone someday.
With the new version file
a.) Change the extension to .zip
b.) Unzip to a folder
c.) Delete app.xml in docProps folder
With the older version
i.) Save any file
ii.) Change the extension to .zip
iii.) Unzip to a folder
iv.) Copy the app.xlm in the docProps folder
v.) Paste this 'old' app.xlm into the folder where you deleted the last one.  You should just be able to re-use this file anytime you want to do this.
Go back to the 'new' version folder:
Re-Zip all folders and files that had been unzipped.
Change extension from .zip to .mcdx
Open in old version
In short, replace the app.xlm file with a version from the older mathcad
(Use at your own risk, no guarantees nothing else changed.  Obviously won't bring new features across)
3-Newcomer
January 12, 2026
Thanks for the suggestion, but this technique did not work for moving from Prime 11 to Prime 9. Opening the updated file in Prime 9 results in an error: "The file type is not supported.  Log file is located at C:\...."
