Study 14. Calculation of Combined (Binary) Cycle
ValeryOchkov
This study describes approaches to calculate the efficiency of a binary power cycle consisting gas and steam turbines. Links to authors web sites with calculations such binary cycles of different types are provided.
Fig. 14.1. Calculation of steam turbine part of the combined cycle
Fig. 14.2. Calculation of gas turbine part of the combined cycle
Fig. 14.3. Calculation of thermal efficiency for the simplest ideal combined cycle
Fig. 14.3a. T-s chart of the simplest ideal combined cycle
Fig. 14.3b. h-s chart of the simplest ideal combined cycle
Fig. 14.3c. Corrected h-s chart of the simplest ideal combined cycle
Fig. 14.3d. Corrected T-h chart of the simplest ideal combined cycle
Fig. 14.4. CCPP with compressor driven by steam turbine - Расчет КПД парогазовой установки с приводом компрессора от паровой турбины
Fig. 14.5. CCPP with single pressure heat recovery steam generator - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-17.xmcd
Fig. 14.6. CCPP with single pressure reheat heat recovery steam generator and multistage air compression - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-12.xmcd
Fig. 14.7. CCPP with double pressure heat recovery steam generator - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-19.xmcd
Fig. 14.8. CCPP with double pressure heat recovery steam generator and application of two-stage feed water heating in the economizer - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-20.xmcd
Fig. 14.9. CCPP with semi-dependent diagram (with regeneration displacement) - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-18.xmcd
Fig. 14.10. CCPP with extraction steam turbine - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-21.xmcd
Fig. 14.11. CCPP with multistage air compression and double pressure reheat heat recovery steam generator - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-22.xmcd
Fig. 14.12. CCPP with triple-pressure reheat heat recovery steam generator - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-16.xmcd
Fig. 14.13. Comparison of gas turbine power plant and steam turbine power plant with CCPP - http://twt.mpei.ac.ru/MCS/Worksheets/PTU/Vv-25.xmcd
See please Maple-sheets here http://www.maplesoft.com/applications/Category.aspx?cid=2886
0 REPLIES 0
