initial value problem-difference method
Hello everyone. I have a problem with a difference method, shown here below. (The results are different from those of the text). Some of you could kindly say me  if I'm wrong or the text is wrong? thanks a lot.
Yours sincerely F. M.
-MFra-Answer
May be my example 18.10-18-12 here Study 18. Differential Equations in Thermal Engineering help you!
-MFra-21-Topaz IIAuthor
Thanks Valery,
the answer is very interesting and very instructive for the use of pdesolve. Thanks again.
However, it does not answer my question, namely: whether  the difference method and the  amplification matrix are correct.
With best regards.
F. M.
I apologize, the differential equation considered, it is with constant coefficients.
-MFra-21-Topaz IIAuthorAnswer
