Oct 1, 2020 6:36 PM UTC
Automatic Tag Generation Refused Due to Active Client Connections
I am having an issue getting an ODBC Client to generate tags. I already have the same setup working for two other tables, but this one is having issues. the full error is "Unable to generate a tag database for <MY DEVICE>:Automatic tag generation for device 'Chem_Results' refused due to active client connections". I can't find what is causing this error. The other two Devices on this channel work fine. The query is valid and pulls the data i expect it to when ran in the oracle sql developer.
7-Bedrock
Oct 9, 2020 12:51 PM UTC
Hi @BP_8854355,
This error occurs if Automatic Tag Generation is attempted while there are active client connections. Changes to the channel.device configuration can't be made while there are clients connected. Close all OPC client connections to the device and retry Automatic Tag Generation.
If this doesn't resolve your issue, please open a support ticket:
https://my.kepware.com/s/contactsupport
Tom
Support
Oct 1, 2020 10:25 PM UTC
Hi @BP_8854355.
Is the product Kepware?  Please confirm, so I can find the right resource to answer your question.
Regards.
--Sharon
Oct 2, 2020 1:07 PM UTC
@slangley yes, this is a kepware product. KEPServerEX 6
Support
Oct 16, 2020 8:00 PM UTC
Hi @BP_8854355.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
