May 2, 2024 9:40 AM UTC
Get surface area in LISP
To get the a part volume, in LISP we can use the function
(sd-call-cmds
(get_vol_prop ...
Is there a way to have the total surface area of a part?
I am using PTC Creo Direct Modellin v20.5.
    May 2, 2024 5:01 PM UTC
    Welcome!
    The get_vol_prop function will also give you other measurements (including area).
    There is a default "rough" tolerance (not sure what that value is) which is used if you use the syntax:
    (get_vol_prop :for_part mypart :area)
    -- this assumes your part has been assigned to the variable mypart
    Similarly, you can get the area of a face using
    (get_vol_prop :for_face myface :area)
    To specify a tolerance, you just need to add a couple of parameters (in this case using a 5 percent tolerance):
    (get_vol_prop :for_part mypart :tol :percent_tol 5 :area)
    As you noted above, you'll need to wrap those calls in (sd-call-cmds ...
    I hope this helps!
    andy
    Welcome!
    I hope this helps!
    andy
    May 3, 2024 5:35 AM UTC
    Thank you very much, Andy.
    Ir works fine!!
    Juan.
    Jul 23, 2024 12:48 AM UTC
    Is there a license?
    Translated text from Simplified Chinese to English using google translate tool.
    有没有授权许可证?
    -By Community Moderation Team
