Mar 15, 2020 1:08 PM UTC
Lauching setup.exe and nothing happens
Hello
I downloaded the 4 Gb zip "MED-100WIN-CD-430_6-0-2-0_Win64" and unzipped it. When I disable my anti-virus and try to open "setup.exe" as an administrator, nothing happens... I tried many times. My Computer OS is Windows 10 and I'm trying to install CREO 6.0
Can someone help me ?
Thank you in advance for your answer,
Have a nice day !
Mar 16, 2020 12:39 PM UTC
maybe the problem is related to network card(s).
Please run ipconfig  /all > ip.txt command in Command prompt window and upload ip.txt file. I can check its contents.
Mar 16, 2020 12:45 PM UTC
Thanks for answering, I did that, it's in french because my computer is configurated in french so I'm sorry for that.
I've uploaded the ip.txt file.
Ludovic
Mar 20, 2020 6:43 AM UTC
@gtjgtj wrote:
I have the same problem.
I can't start the Setup.exe file either. First the normal Windows prompt appears asking if you want to install it. But then nothing happens.
I have Windows 10 Version 1909, 64bit
Enclosed my IP.txt file.
If I have to change something - where exactly do I have to change it - but not in the txt file...?
I'd appreciate it if you could help me, too
1.]
User named Ludo_ENSMM resolve his problem by creation a new local user on his computer. Did you try this tip ?
2.]
I do not understand why your active LAN connection is ... Ethernet-Adapter Ethernet 3 network card (Physical Address: 9C-EB-E8-45-D6-9D) ... do you have notebook plugged in docking station ?
3.]
If I were you I would disable all network cards (physical and virtual) except Ethernet-Adapter Ethernet 3 network card (Physical Address: 9C-EB-E8-45-D6-9D) and uninstall/install Creo. This procedure should force Creo installer to generate license related to MAC address of WiFi network card.
Before you start installation, check whether C:\ProgramData\PTC\Licensing directory is empty.
The directory does not exist if you install Creo for the first time.]
4.]
Please read uploaded PDF documents.
3-Newcomer
Apr 20, 2022 11:17 AM UTC
Hi there,
I had this same problem yesterday. In my case, the problem was that the installation folder was in the "downloads" folder.
As soon as I moved it to C: and launched again the install.exe, everything worked fine.
Hope it helps someone (or at least my future me in a couple of years 😉
