Jan 22, 2019 1:42 PM UTC
Ptc creo 3.0 not running
I have installed ptc creo 3.0 but after installation the programmes doesn't run at all. Can anyone solve this problem
Jan 24, 2019 4:11 PM UTC
try following ...
Jan 28, 2019 6:23 PM UTC
this process is not working, The problem is not only parametric but every
program of the creo is not running
Jan 29, 2019 6:19 AM UTC
1.] check the contents of C:\ProgramData\PTC\Licensing directory, installer puts license file into it
Note: If you are note able to verify validity of license file, please zip it and upload zip file
2.] maybe your problem is related to some network card
Please open DOS propmt window, run following command and upload ip.txt file
ipconfig  /all  > ip.txt
