Jan 15, 2016 8:39 PM UTC
M200 Student Quality Agent
Hey, I installed Creo 2.0 M200 today, but it won't work, because the Quality Agent is not installed. And also the file qualityagent_64.msi is not in the install/addon folder. Can somebody please upload this file, so I can install it?
    Jan 17, 2016 6:07 AM UTC
    Okay, so I faced a similar issue. The app opens, but then a warning window pops up about that ''Quality Agent'' issue and then the app shuts down automatically.
    I just uninstalled and re-installed it, and it worked this time. I just turned off the Firewall while installing it this time, and it worked.
    Jan 17, 2016 9:20 AM UTC
    Same exact problem. Even tried a clean install of windows 7 32bit, and an older version of creo (m180). Nothing works.
    Jan 18, 2016 2:34 PM UTC
    Same problem with windows 10 the error is actually 0x06000003
    Jan 18, 2016 10:20 PM UTC
    Same problem here. Tried reinstalling, running as administrator, etc. Error code 0x06000003. Windows 8.1.
    Jan 24, 2016 4:16 AM UTC
    Same problem, spent hours trying every solution offered. Using Win 10 system, and it doesn't seem that their is a 64 bit option for the quality agent.
    Jan 28, 2016 2:41 PM UTC
    Hi Fabian,
    This is a known error with Creo 2.0 M200, and the development team is working hard to find a solution ASAP. I will let you know once we have a fix.
    Chris
