Can't open Creo Parametric 9.0.0.0
  • June 20, 2023
  • 24 replies
  • 17015 views
I tried opening Creo, but it doesn't start. Any help would be kindly appreciated.
Best answer by MartinHanak
@JJ_10108058 wrote:
Hi Martin,
I checked again and a std.out file was created.
I am running Windows 11 in Parallels on Mac.
Jonathan
now it is clear ... Creo does not run on Apple M1 Pro processor. Only Intel/AMD is supported.
please provide more details.
Hi Martin,
Thanks for your response. I installed Creo and everything worked just fine. When I double click the icon shown below, to open the application, I see a short loading sign, and then nothing happens. If I check the Task Manager, the Program isn't shown in the list, which means that it hasn't startet. Is there any other way to launch the application?
Thanks a lot for your help.
BR Jonathan
Q1:When was the last time Creo worked?
Q2:What has changed?
Q3:When you start Creo, is std out file created?
Q4:Did you look into Event viewer?
11-Garnet
August 24, 2023
You can run Creo 10 (or earlyer version) on Mac M1 with Parallel Desktop 19.
Edit C:\Program Files\PTC\Creo 10.0.1.0\Parametric\bin\parametric.psf and add this line at the start:
ENV=PRO_MACHINE_TYPE=x86e_win64
Károly
Information source ...
https://www.parallels.com/eu/products/desktop/whats-new/
Note: I am almost sure that PTC does not support this environment.
11-Garnet
August 25, 2023
Yes It is not supported by PTC but It works. 🙂
Károly
11-Garnet
July 21, 2025
Here is a youtube video for installing Creo 12.4 on MacBook Pro with Parallels Desktop V20 using Windows 11 ARM version:
https://youtu.be/gyEGe5WZHMM
Károly
