Feb 21, 2017 7:48 AM UTC
Can't simulate in Creo Parametric(student edition)
I try to use the simulate lite feature in creo parametric because the student license does not include the full simulate program, but nothing happens. When I click simulate, the message log at the bottom reads "Leaving Creo Simulate for the model...." and that's it. I'm trying to do a force analysis, is there another way to do this?
Emeritus
Feb 21, 2017 1:01 PM UTC
Good day Sarah,
I am moving this to the academic community to give your question the most exposure.
Best,
Toby
Apr 8, 2018 4:40 PM UTC
Iam also haveing this problem, makeing the creation of my thesis harder. I've also sent a message to the support about an other question, but it seems like PTC dont care about students. Zero response, for both topic.
Apr 9, 2018 3:06 PM UTC
@aabdulkarim
@Alex_Cazacu
Please check it.
Sep 17, 2019 4:43 PM UTC
Aug 10, 2020 10:54 AM UTC
If the Simulate is not opening and the window where you can choose Lite is not opening, most likely you didn't install Creo Simulate.
Run setup.exe and follow the process (without licensing again, as the license is valid) and in the list of the features to install, make sure that you have Creo Simulate checked to be installed.
Alex
