Creo 5.0 Premium Edition Standalone Educator CFD licence
Hi, I just installed the Creo 5.0 Premium Edition Standalone Educator edition of Creo in order to help mentor my FRC robotics team. I was excited to try out the new simulate capabilities. When I installed, I went into the "application feature" section of the installer, and saw that "Creo Flow Analysis" and "Creo Topology Optimization" were unchecked. I checked their boxes and continued installing.
Now, Creo simulate appears to work well, and topology optimization opens as well! Unfortunately, when I click "Flow Analysis", it tells me that "The selected functionality requires CFD Analysis License".
When I go to file->options->licensing, and click Refresh license list, I see an optional floating license called CFD_ADVANCED_PLUS_SET. If I select this floating module, it says that it's been activated, but still won't let me open flow analysis. It says:
Option CFD_BASIC not ordered, please contact your sales representative.
Option CFD_ADVANCE not ordered, please contact your sales representative.
Option CFD_ADVANCE_PLUS not ordered, please contact your sales representative.
What should I do? Is flow analysis actually included with the premium educator license?
Thanks so much,
~Max
CFD is not working yet in any product code based license.
We are working on this, but sadly I can't tell you when it will be available.
Alex
Hey, Is there any update about whether this is possible now?
Thanks for your time!
~Max
Hi, i got the same issue whereby a CFD license is need for flow analysis. how do I resolve this issue?
Regards
Was this ever solved? I’m having the same problem
@mtepermeister
open parametric.psf file in Notepad (path example ... E:\PTC\Creo5_040\Creo 5.0.4.0\Parametric\bin).
Check line starting with ... ENV=CREOPMA_FEATURE_NAME=
Add 10131 into parentheses.
The line should look like ... ENV=CREOPMA_FEATURE_NAME=PROE_some-name (10131)
Note:
  • 10131 is code number of CFD_ADVANCED_PLUS_SET
I did that and when I restarted creo I got the error: "Features Not Obtained: CFD_ADVANCED_PLUS_SET"
Hi, does anyone know why im getting this error?
