Jul 5, 2018 8:30 PM UTC
Creo 5.0 Student License
I followed the directions for install and license, however when I try to launch any of the Creo Application they return a license error, even though the license is located correctly. I would note that Creo Direct on launch just terminates without message where the other 4 applications return a license error, when I select OK the application(s) close
Gregchop1-VisitorAuthor
Jul 5, 2018 11:02 PM UTC
Seems you dont have a student license for 5.0 is that correct ?
Jul 6, 2018 9:51 AM UTC
Hi, I have the same problem: I have both installed Creo 5.0 following the instructions provided from PTC and gone through the configuration process described by PTC in the "School Configuration Guide", although when I run the program it shows me a message that says: "License request failed for feature". I'm not an expert of computers and I have no clou what that means, if you know what the problem is could you please tell me and maybe suggest me what I can do to solve it?
Thank you
Sep 11, 2018 8:23 AM UTC
I have the same license error. Has anyone found a solution?
Sep 5, 2018 8:57 AM UTC
Please submit your request in "Academic Support Request" form: Academic Case Logger
Dec 5, 2018 10:20 AM UTC
just do this
1) uninstall creo parametric 5.0 (only) and
2) remove licencing files permanently from your machine , from recycle bin also
2) go to setup again and start installing
3) in licencing use code:- BK500806ED0790-Y3M9-4RW5
4) enter your ID and password and click install
restart your machine
good to go
let me this worked for u or not
Dec 6, 2018 4:09 AM UTC
Worked for me, thank you for the help!
Apr 27, 2020 12:19 PM UTC
licence has changed for creo 5.0. Use "BK500806ED0790-Y3M9-4RW5" and follow same process from starting. It will work.
