How to Fix "Fatal Error Encountered. A traceback has been written"
  • August 27, 2014
  • 23 replies
  • 60285 views
Problem Outline:
After installing Creo 2.0, and while attempting to launch it the following error message appears...
"Fatal error encountered. A traceback has been written to C:\Users\Public\Documents\traceback.log. Please send it to Technical Support."
This problem is because of an issue with an Intel Embedded Graphics card. This can happen when the Intel card is either the primary or a secondary GPU on the machine. The problem is most common on Creo 2.0 datecodes M090-M010.
Solution:
Fortunately the solution to his problem is relatively simple. By placing a configuration file in the "start-in" location of Creo 2.0 (by default it's public documents) Creo 2.0 will handle the integrated card in a different way, bypassing the error.
  1. Download the attached config.pro file
  2. Move the config file to C:\Users\Public\Documents
  3. Restart Creo 2.0
    Thank you!!!
    This solution did not work for me, any other suggestions? I have tried to install and reinstall this program over and over but I continuousely get this same error message. I am trying to download the student version, if that makes any difference. Any help would be greatly appreciated!
    MarkCheli5-Regular MemberAuthor
    Hi Markie,
    There's one other possible solution and that involves switching out the contents of the config.pro file in the instructions above. Simply open the config.pro file located in the public documents folder with a text editor (such as notepad) and then change the text to read...
    graphics win32_gdi
    This should be the only line in the config.pro file. Let me know if you have any questions!
    That doesn't seem to have worked either. I have followed the instructions on the download, so I'm not sure what it could be? I'll attach the traceback and see if that helps.
    Thanks alot.
    I am facing this issue many times. Your post really works.
    Thanks again.
    One of our users has just started experiencing this error.  We've tried the solution described, but it hasn't had any effect.  Do you have any suggestions?
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS101097
    Hi, this didn't work for me etiher.
    Can you help me out? Here's my traceback file
    I too am encountering this fatal error continuously. My traceback file is attached, and I've tried all the suggested fixes in the forums.
    it will work but after that again show the message
    Hi, I am facing the same issue in Creo 5, While working on Part modeling can i use this config.pro file fix the.problem?
    I to have same issue with fatal error encountered. A tracerback has been written in creo 5.0
    Kindly anybody help me get out of this issue.
    I am operating with windows 10 OS with 2 GB AMD Radeon graphics card.
    Problem arises few min after start working with part modeling.
    Please help.
    Thank you
    First, please try updating the graphic card driver and make sure it is working properly.
    If this don't fix the issue, Try this:
    Right-click on the Creo Parametric shortcut on the desktop and go to properties. Add space after the existing target path and then -g:win32_gdi. Click on apply and run the Creo
    Alex
    This same error occured with using sketching in CREO 6.0.2.0 student edition, please help me with it, attaching a trace file.
    My laptop specs are as follows,
    Laptop: Lenovo Ideapad 510s
    RAM: 8GB
    Processor: Intel i5-7200U CPU@ 2.5Hz
    System: 64bit
    Graphics card 4GB: 1. Intel HD Graphics 620
                                     2. NVIDIA GeForce 940MX
    @Alex_Cazacu
    how to fix the traceback error..my traceback file is..
    Plz give me creo 7.0 version file
