exception_access_violation
I have to use Creo 2.0 for university. Due to this, I downloaded and installed the student version.
While the installation process ran without any problems, Creo does not run right now.
When I try to launch Parametric, it crashes with the error "exception_access_violation".
I have already tried to install the latest graphics driver (Intel HD 4000), but that does not
solve the problem. Furthermore I tried the "enable_opengl_fbo no"-option, unfortunately
the problem is still here (Is the spelling "enable_opengl_fbo no"
correct or have I to write it otherwise?). Is there any solution for that issue?
Kind regards,
Simon Hemmerich
    MarkCheliAnswer
    Hi Simon,
    Can you please fill out a academic support request?
    http://www.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
    We should be able to help you afterwords with your license.
    Simon,
    try to add the following option into config.pro file:
    graphics win32_gdi
    Martin Hanak
    Martin,
    thank you for your fast answer.
    I followed your advice, but the problem is still there. Are there any other possibilities?
    Simon Hemmerich
    Simon,
    unfortunatelly I do not know, what is the root of your problem.
    It can be:
    • graphics
    • corrupted Creo installation
    • some problem inside Windows
    In case of graphics problem PTC recommends set following options inside config.pro.
    enable_opengl_vbo no
    enable_opengl_shader no
    graphics win32_gdi
    enable_opengl_* options have some effect in Creo Parametric 2.0 M090 and higher (I guess)
    Martin Hanak
    Mahesh_Sharma
    22-Sapphire I
    June 3, 2014
    Simon,
    You may try renaming cache folder (.wf) at C:\users\<User Login>\AppData\Roaming\PTC\ProENGINEER\Wildfire.
    Once renamed, try launching Creo.
    Note: If you are unable to find AppData folder, please unhide folders.
    Which version and datecode of Creo you installed?
    You can type %APPDATA% into address field of Windows Explorer to see the contetnts of C:\Users\USER\AppData\Roaming directory.
    Martin Hanak
    First I want to apologize for not answering so long.
    I was very busy with exams.
    Unfortunaly, none of the given advices solved the problem.
    Are there any possibilities left to solve it?
    Furthermore, one little question to the PTC employees:
    Is it possible to unlock my license, so that I am able
    to install Creo on another PC? This would be good because
    I need it for university...
    Kind regards,
    Simon Hemmerich
    Mahesh_Sharma
    22-Sapphire I
    June 18, 2014
    Simon,
    One more trial for you:
    1. Right Click on Creo shortcut icon on desktop > Select Properties
    2. Move the cursor to end in target path > Add a empty space followed by -g:win32_gdi > Apply > Ok and launch Creo.
    This has solved my problem of launching.
    Mahesh_Sharma
    22-Sapphire I
    June 19, 2014
    Moving the post to Academic Support as Martin suggested.
