3-Newcomer
September 7, 2021
Conversion From 15 to Prime 7 Failed
  • September 7, 2021
  • 2761 views
I am still in the process for which version of mathcad to go with. I was wondering if you would be able to help me out. I did a conversion from Mathcad 15 to Prime 7 but it seems that it converted the table in 15 to a matrix and now none of the equations work anymore. Is this something you can help me with?
Best answer by VladimirN
Please find my solution in the attachment. I used an external text file as raw data table. You only need to change the path to this text file.
Can you attach both worksheets?
3-Newcomer
September 7, 2021
VladimirN, see below for attached. Is there a way to get the converter to keep the table in table form instead of transforming it into a matrix? I have not purchased a license yet and am debating trying to extend my time with Mathcad 15 for a few years.
Thank you for your quick reply.
VladimirN24-Ruby IIIAnswer
